Speedometer not working
87,238 MILES • 6 CYL • 2WD • AUTOMATIC
SHORTYJCP
Hello, the speedometer is not working i already took off my cluster to check for anything, but cluster seems fine connections behind the cluster fine too. i did buy speedometer sensor but nothing, it's not the sensor either. What can be the problem?? Can you guys help me with this? thanks in advance
Sep 3, 2010 at 10:36 PM
  • 110,248 POSTS
If you replaced the VSS and the wiring to the speedometer cluster is good, it sounds like the cluster itself is the problem.
Sep 5, 2010 at 4:06 PM
SHORTYJCP
thank you very much.
Sep 6, 2010 at 12:51 PM
  • 110,248 POSTS
Let me know what you find.
Sep 6, 2010 at 3:06 PM
LEONNARDOL
hey um, if you still have the problem with the speedometer cluster i recommend you to check the fuse relay inside the truck, because my dad's 2002 Ford f250 speedometer cluster didn't work and he replaced the burned relay with a new on and then it started to work.
Apr 11, 2022 at 12:41 AM
  • 110,248 POSTS
Thank you for that information. I feel it will help others in the future.
Apr 11, 2022 at 10:55 AM
