Some sort of wire going into the Manifold
165,000 MILES • 2.0L • 6 CYL • 2WD • AUTOMATIC
NICOLELMADSON
When the POS is on, oil leaks from a wire that is coming from the manifold. There's just one wire
Jun 11, 2014 at 11:13 PM
  • 110,251 POSTS
Not sure what POS is. If you have an electrical sensor that has oil leaking from it, 99.9% chance it is the oil pressure switch (sending unit). Not an expensive part. If you can take a picture of it, I will have a better understanding of what it is.
Jun 12, 2014 at 9:47 AM
