2003 Volkswagen Jetta Oil Leak
2003 VOLKSWAGEN JETTA
144,000 MILES • 4 CYL • 2WD • AUTOMATIC
MGIAMPIETRO
Purchasing a 2003 Jetta with a slight oil leak. The engine already had timing belt & water pump changed at 105,000.
Can anyone help assess risk & possible repair of the leak?
Aug 17, 2009 at 4:46 AM
BILLYMAC
  • 2,204 POSTS
where exactly is the oil leaking front of eng rear top side?
Aug 17, 2009 at 9:11 AM
MGIAMPIETRO
Only sure thing is that it appears it is not coming from the front or the top.
I assumed that they had the head off at 105K when the timing belt & water pump was changed. However, that was 40,000 miles ago.
Aug 18, 2009 at 1:53 AM
BILLYMAC
  • 2,204 POSTS
HI
Well if from the bottom this could be one of thre things worst would be rear main seal 500 .00 repair
or the oil pan maybe 200.00
or the oil sender less then 100.00 good luck billymac
Aug 18, 2009 at 4:24 AM
