Does not want to start when hot
  • 109,755 POSTS
Okay, at this point, we need to know if you are losing spark when this happens. Can you check that?
Friday, December 15th, 2017 AT 5:02 PM (Merged)
CHIPET
  • 2011 SKODA OCTAVIA
  • 1.6L
  • 4 CYL
I tried start the vehicle it will not start, I've change the fuel pump, engine censor, I've even done baick setting if it manage to start it will not hold steaming
  • 31,937 POSTS
You need to be checking for any fault codes with a scan, also check for fuel pressure and flow, spark and injection pulse, can you do this?
LISAMARIE000
  • 2000 SKODA OCTAVIA
2000 Skoda Octavia 6 cyl Front Wheel Drive Manual
my car starts then I press on the excelerator and it konks out
DAVE H
  • 13,383 POSTS
Have the vehicle plugged into a diagnostic computer to locate the cause of the fault. Possibly the TPS (throttle position sensor)
2CP-ARCHIVES
  • 4,540 POSTS
  • 2005 SKODA OCTAVIA
Engine
do not starting morning
Go to this walk thru link for more information: https://www.2carpros.com/articles/car-cranks-but-wont-start
E HOLLAND
  • 2003 SKODA OCTAVIA
  • 4 CYL
  • MANUAL
  • 198,000 MILES
2003 Skoda Octavia 4 cyl Two Wheel Drive Manual 198000 miles
I recentley changed the cambelt on my 1.9tdi engine which then would not start so I towed it to the local skoda dealer who have verified that the timing is ok but are now struggling to find the fault.I changed the fuel filter and glow plugs after doing the belt and prefilled the filter with diesel and cracked off the injector pipes and diesel spurts out so it seems to be injecting. The dealer has also verified that the compressions are good and that the camshaft is not broken. The only other thing that happens when cranking over the engine a lot of white smoke is omitted from the exhaust below the manifold. Any help you can give will be greatly appreciated, many thanks E.
DAVE H
  • 13,383 POSTS
Repair the leaking exhaust !
