Hello kcheese
Welcome to 2carpros. Com
There is no engine light/engine codes. We can start the diagnosis with what I thing is most likely the problem.
You have compression and engine flooded sometime.
We need spark for the engine to start.
#1
Remove a plug wire and insert an old spark plug or a spark plug tester into the end of the wire (the plug boot). Place the spark plug on a metal surface on the engine, or ground the spark plug tester to the engine. Then crank the engine to check for a spark. No spark indicates an ignition problem.
Look for a nice blue spark, not yellow one.
Get back to me if there is or not spark.
SPONSORED LINKS
Tuesday, February 9th, 2021 AT 9:51 AM
