2002 Saturn Vue drags down engine
MICHELLE_OLSON41
  • 2002 SATURN VUE
  • 4 CYL
  • FWD
  • MANUAL
  • 15,000 MILES
Vue would not start after work, called towing, had jump start, left parking lot. Vue died in intersection. Tow truck came back towed to shop. Shop replaced battery. Next day, when AC was on, almost killing at stop signs, 'cycling' down to 200 RPMs or less then back up to 800 then back down then up. Turned off AC and it doesnt do it. Same shop was not sure, suggested taking it to the 'city'. Said maybe computer?
Sunday, June 27th, 2010 AT 1:12 PM
SATURNTECH9
  • 30,869 POSTS
Let's do this to start take it to a auto part's store like auto zone and have it scanned for code's. If you have any let me know the number's and we will go from there.
Tuesday, February 9th, 2021 AT 9:51 AM
MICHELLE_OLSON41
Louie, there are no codes. The first shop checked for them.
SATURNTECH9
  • 30,869 POSTS
If there are no code's I would suspect since it only doe's it with a/c on that the a/c compressor or a/c clutch maybe at fault. Causing to much of a load on the engine. Did the shop ever check that possibilty out?Also when the engine is cold see if the center of the a/c clutch turn's freely.
MICHELLE_OLSON41
Louie, the inside of the clutch will spin, not like free wheelin but it will turn with just a little effort.
Tuesday, February 9th, 2021 AT 9:52 AM
SATURNTECH9
  • 30,869 POSTS
Let's try this start the car and let it idle with the a/c on then watch the center of the a/c clutch does it spin then not spin then spin again?
