1995 Saturn SL2 Starting problem
SIMTHEMBILE
Electrical problem
1995 Saturn SL2 4 cyl Front Wheel Drive Manual
We've been having intermittent starting problems, the starter is still good (took it out and had it tested), the battery is testing fine, the alternator above average. there is a slight trend for it to start better when cold, though it is not always that way. I have successfully jump started it once, though on another occasion jumping failed to help. it roll starts just fine. i have also replaced the battery terminals as the threads were stripped.
Aug 13, 2010 at 3:03 PM
SATURNTECH9
  • 30,868 POSTS
So are you getting a no crank no start especially when hot?Also do you have a multimeter?
Aug 13, 2010 at 3:13 PM
SIMTHEMBILE
yeah, we get the lights, ac, radio, everythings powered, but no crank, its intermittent, it seems it starts more often when cold, but i don't know if that trend is consistent enough to call a trend. i don't have a multimeter, but i can get one.
Aug 13, 2010 at 3:57 PM
SATURNTECH9
  • 30,868 POSTS
Alright let me know when you get a multimeter or test light and i will give you the next step.
Aug 14, 2010 at 5:54 AM
