1998 Saturn SL1
1998 SATURN SL1
JARVIS CORLEY
Transmission problem
1998 Saturn SL1 4 cyl Two Wheel Drive Automatic
i have a 1998 saturn and i brought it from a friend and he was having transmisson problems. i brought another one and it stays in the high gear. this happen on both transmissions. what can i do to fix this problem? its a pretty good car the engine runs really good and and its very clean and i dont want to get rid of it. so please tell me something on what i can do to fix this problem without taking this transmission out the car again.
and what are the chances this transmission going out ?.
or do you know if saturn had problems with there transmission.
Nov 2, 2010 at 6:50 PM
SATURNTECH9
  • 30,869 POSTS
So it stay's in high gear it won't down shift into the lower gear's?Do you have any code's?
Nov 2, 2010 at 7:00 PM
JARVIS CORLEY
no i dont have the code yet im going to get the code for thAT tomorrow. a friend has a code reader so maybe be can tell me what it is.
Nov 2, 2010 at 7:08 PM
JARVIS CORLEY
do you have any suggestion just off the top of the head
Nov 2, 2010 at 7:09 PM
SATURNTECH9
  • 30,869 POSTS
With the little info i have so far not really the more detail the better.Keep this in mind i can't test drive your car to see how it's shifting or check it for code's etc.I asked you if you were saying it stay's in like 4th gear and won't down shift when it's supposed too?Also does it shift hard or slip etc?Does it shift better cold etc?paint me a picture in my mind.
Nov 2, 2010 at 7:18 PM
GARY IN ST. CHARLES
  • 5 POSTS
I have a 1999 Saturn sl2 doing the same thing. It is in a high gear and won't up shift or down shift, not even manually. It has codes 782 &783.
Jan 16, 2017 at 10:37 AM
SATURNTECH9
  • 30,869 POSTS
Could you please start your own question it makes it difficult to start a new question on someone else's question.Just to confusing for me and other users searching questions to help them.start the question with this one is for Saturn Tech9 then they will leave it for me.Iam the Saturn factory trained tech on this site.
Jan 16, 2017 at 11:36 AM
GARY IN ST. CHARLES
  • 5 POSTS
I have a 1999 Saturn sl2. It starts out very sluggish like it's in 3rd or 4th gear. It does not shift up or down not even manually. It has a 782 & a 783 code both referring to ratio problem.
Jan 16, 2017 at 11:46 AM
SATURNTECH9
  • 30,869 POSTS
Again please start your own question not on someone else's question but your own question.
Jan 16, 2017 at 12:32 PM
GARY IN ST. CHARLES
  • 5 POSTS
I guess I don't know what you want. I just described what my car is doing. It won't shift up or down and it feels like it starts out in 3rd or 4th gear very slavishly and has a code 782 & 783 telling me it has ratio problems. It will not shift up or down manually as I drive it.
Jan 17, 2017 at 10:59 AM
GARY IN ST. CHARLES
  • 5 POSTS
This question is for Saturn tech9. I have a 1999 Saturn sl2. The trans seems to be starting out in a high gear and won't shift up or down automatically or manually.
Jan 17, 2017 at 11:52 AM
SATURNTECH9
  • 30,869 POSTS
I want you to start your own question not on this question.That's what Iam asking you to do.
Jan 17, 2017 at 12:52 PM
SATURNTECH9
  • 30,869 POSTS
Go to your account and click the link there that says ask a question.Then ask your question.
Jan 17, 2017 at 12:53 PM
