If your fan isn't running then if your a/c work's then turn it on your fan should come on if it does then your fuse,relay,wire's, fan motor etc are good.If your fan doesn't come on then test for power and ground to your motor if you have power and ground then bad motor.If your a/c doesn't work then here's what you do turn your a/c on go over by your left strut tower there will be your high low switch on your a/c line unplug it and jump the two terminals together for a few second's this should send the signal to turn the fan on.if the fan doesn't come then test for power and ground like before.Let me know what you find.
Jul 17, 2010 at 6:19 AM
