Engine Mechanical problem
1996 Saturn SL1 4 cyl Two Wheel Drive Automatic
When changing plugs and wires, I found oil in the first cylinder. What do you suggest I start with?
Sunday, May 9th, 2010 AT 12:39 PM
SATURNTECH9
MECHANIC
Do ur spark plugs face straight up or are they angled towards u. Let me know and I'll help u out with ur problem.
Sunday, May 9th, 2010 AT 12:51 PM
JAKE1954
MEMBER
The spark plugs come straight up.
Sunday, May 9th, 2010 AT 1:31 PM
SATURNTECH9
MECHANIC
Then u have a sl2 not a sl1 sl1's are single cam the sl2 is a twin cam. All u have to do is change ur valve cover gasket when u put the valve cover back on make sure u put a bead of silcone across where the front cover meets the head the surface that the valve cover gasket goes againist. Also put a coat of silcone on the head around the four spark plug holes when u put the valve cover back on. Let me know if u have anymore questions.
