1996 Saturn SW1 Hot No-Start
SATURN
JOE P
my 1996 saturn sw1 ,112000 miles wont start when engine is hot but starts and runs fine when i first start it in morning. Starts normally and runs fine untill I turn off ignition. Then it won't restart for about an hour. All electrical operates normally, radio. lights. etc. When key is at start posistion engine will crank, but wont restart. It seems that something needs to cool down. Then it will restart and operate normally untill I turn it off.
What can cause this problem? I have spark and replaced coil packs, what else can i try?
Jan 10, 2007 at 10:01 PM
PEPPERMRJ
  • 1,158 POSTS
Have you replaced the coolant temperature sensor with the updated brass tipped one from saturn?
They will cause everything from poor fuel economy, high idle and no starts.
Good luck and let us know. :)
Feb 7, 2007 at 10:32 AM
Suggested Repair
Replace the coolant temperature sensor with the updated brass-tipped Saturn sensor, which can cause a hot no-start.
Conversation Summary
A 1996 Saturn SW1 with 112,000 miles starts and runs normally when cold but will not restart for about an hour after the engine is shut off while hot. It cranks and electrical accessories work, and the owner already has spark and has replaced the coil packs. The expert suggested replacing the coolant temperature sensor with the updated brass-tipped Saturn part, noting it can cause no-starts as well as poor fuel economy and high idle.
