1996 Saturn SW2 No Start After Long Drive
SATURN
JCC1986
I have a 1996 Saturn SW2 Wagon. Lately I have been having a problem where anytime I drive fro a long distance, once I turn the engine off it wont start. I can jump start the car and it starts right up, or I an come back after a few hours and it starts right up. I can drive short distances and I will have no problems, is only whne I drive long distance (over 30 miles)???
Sep 19, 2007 at 8:45 AM
SERVICE WRITER
  • 9,123 POSTS
I 've seen some weird things wiht the igntion switches on those. My hunch is it may be an alternater issue, but try this anyways. Before you drive it, take a hairdrier and heat the ignition switch up somewhat and see if the problem starts right then. If not I would have the charging system checked.
Sep 19, 2007 at 10:46 AM
Suggested Repair
Before a long drive, warm the ignition switch with a hair dryer and see if the no-start happens immediately. If it does not, have the charging system and alternator checked.
Conversation Summary
The owner of a 1996 Saturn SW2 wagon says the engine will not restart after drives over about 30 miles, but it starts with a jump or after sitting a few hours. Short trips are fine. The expert suspects the ignition switch or alternator and suggests a heat test of the switch, then a charging-system check if that does not reproduce the fault.
