is the theft light on?
also are you trying to use a key that is not coded by the dealer?
try using some graphite lock lubricant sprayed into the cylinder and on the key, does that help it turn?
Put more pressure when turning the wheel left when turning hte key, or put more pressure when turning the wheel right, takes some effort.
another cause could be a damaged key, try using your spare, if neither of those work and you have done all the aboe it is time to replace the ignition cylinder.
Nov 27, 2007 at 11:09 PM
