2001 Saturn SL2 Idle Surge and -40 Temp
2001 SATURN
DBGAUGER
I'm having engine idle problems. When stopped, car in drive, the engine will rev to about 1500 rpm's then settle back to 800 rpm, usually. Sometimes when I stop and then put it into park it will rev to about 3000 rpm. It seems to also fluctuate while driving
I replaced the Idle Air Control valve and cleaned the EGR valve. No real improvement.
Any suggestions would be appreciated
Nov 8, 2007 at 1:24 AM
2CARPRO JACK
  • 11,533 POSTS
Has the check engine light been on? Check for vacuum leaks at the engine. If the light has been on, have it scanned for codes, might give us a place to start
Nov 8, 2007 at 11:54 PM
DBGAUGER
No check engine light. I replaced the coolant sensor. The scan is showing that the engine temp was at -40-degrees. Obviously not correct.
Are there two coolant sensors on this engine?
Nov 12, 2007 at 9:44 AM
2CARPRO JACK
  • 11,533 POSTS
There is a coolant sensor (PCM) temp sender (gauge) and air intake temp sensor (PCM)
Does it still read -40 ? be sure you replaced the right one, the temp sender and coolant sensor look alot alike on Saturns
Nov 12, 2007 at 11:29 PM
DBGAUGER
I replaced both sensors and it's still reading -40. After replacing the sensors it corrected it for a short time. Could it be the computer itself?
Nov 19, 2007 at 1:50 PM
2CARPRO JACK
  • 11,533 POSTS
Could be, but first you will need to do a pin to pin resistance check on the wires to be sure they are good to the PCM
Nov 19, 2007 at 11:52 PM
Suggested Repair
Before replacing the PCM, perform a pin-to-pin resistance check of the coolant temperature sensor wiring to the PCM. Confirm the correct sensor was replaced, since the PCM coolant sensor and gauge temperature sender look similar, and also check for vacuum leaks.
Conversation Summary
A 2001 Saturn SL2 with 134,000 miles surges at idle, sometimes reaching about 3000 rpm in park, and fluctuates while driving. The idle air control valve and coolant sensors were replaced and the EGR valve cleaned, with no lasting improvement and no check engine light. A scan still shows about -40 degrees after a brief correction. The expert advised verifying the correct sensor and testing the wiring to the PCM before suspecting the computer.
