2002 Saturn SL2 Rough Idle
2002 SATURN
SAMURRAY
I have a Saturn SL2, 2002 model with 64,500 miles on it. It has recently started idling strangely. When I come to a stop, the RPMs will jump up and down, then it will idle very low and it will act like it is going to quit all together. It did this a while back, but then it stopped doing it. The last time I went for an oil change they told me that I needed to have my serpentine belt changed the next time that I came in. Is it possible that this could have anything to do with it? If not, what could I ask them to look at to find out what the problem might be?
Dec 27, 2006 at 5:33 AM
2CARPRO JACK
  • 11,533 POSTS
No, the drive belt wont do that.At that mileage your pretty much due for a tune up.Start with the basics. Service the fuel injection and decoke the throttle bore.Service the Idle Speed Control motor and tune it up with OEM parts. If the problem continues it might need to be put on a scanner to see what's wrong
Dec 27, 2006 at 5:52 AM
Suggested Repair
The serpentine belt is not the cause. Perform a tune-up with OEM parts, service the fuel injection, decoke the throttle bore, and service the idle speed control motor. If the idle problem continues, have the vehicle scanned.
Conversation Summary
A 2002 Saturn SL2 with 64,500 miles surges at stops, then idles very low and nearly stalls. The issue happened before and then stopped. The owner asked whether a recommended serpentine belt replacement could be related. The expert said the drive belt would not cause this and recommended a tune-up with OEM parts, fuel-injection service, throttle-bore decoking, and idle speed control motor service, followed by a scan if the problem continues.
