1999 Saturn SL1 Low Idle Check Engine
1999 SATURN
REDSNIPPER
I have a '99 Saturn SL1 single cam. For weeks the Service engine light has been on & I have replaced the O2 sensor, cam shaft position sensor, Idle Air Control Valve, and the PCV valve. The light is still on and the engine continues to idle low in park. It almosts wants to cut off. at times.
Any ideas>
Jan 12, 2006 at 11:48 AM
PEPPERMRJ
  • 1,158 POSTS
[quote:9e518d4560="Redsnipper"]I have a '99 Saturn SL1 single cam. For weeks the Service engine light has been on & I have replaced the O2 sensor, cam shaft position sensor, Idle Air Control Valve, and the PCV valve. The light is still on and the engine continues to idle low in park. It almosts wants to cut off. at times.
Any ideas>[/quote:9e518d4560]
First thing to do is have the codes read and post back with them. I do believe that autozone stores will scan the codes for you free of charge.
Good luck and let us know.
Feb 1, 2006 at 11:28 AM
Suggested Repair
Have the diagnostic trouble codes read and post them for further diagnosis. AutoZone may scan the codes at no charge.
Conversation Summary
The owner of a 1999 Saturn SL1 reports a persistent service engine light and a low idle in park that nearly stalls, despite replacing the O2 sensor, camshaft position sensor, idle air control valve, and PCV valve. The expert advises reading the trouble codes first and posting them, noting that AutoZone may scan them for free.
