2000 Saturn SL1 Low Idle
HRDVORAK
Hello and Good Morning/Afternoon/Evening. :)
I have a 2000 Saturn, SL1 and I've got a problem.:)
As of this morning, my idle is so low that it almost dies. It does this not only on start up but when I come to a complete stop. Is this a battery issue, alternator or something different. (she has 123,900 miles on her).
I do know that i need a new battery but I didn't think my battery was responsible for the idle once the car was running. (i had a 100,000 check up done and do have a new serptine belt on her)
Your help and advice DESPERATELY sought after.
Heather
Apr 4, 2006 at 2:51 AM
PEPPERMRJ
  • 1,158 POSTS
On a saturn the battery runs everything. The alternator is just there to recharge the battery. Replace it if it is failing. Might solve all the other problems. Make sure you fully charge it before installation.
Good luck and let us know. :)
Apr 4, 2006 at 2:12 PM
HRDVORAK
Oh, thank you, thank you, thank you for your quick and expert response. :D
Funny thing is now the stupid thing is behaving just fine. :x Darn thing!
I will give that a shot and let y'all know the success of it; i still need a new battery.
Heather
Apr 5, 2006 at 5:43 AM
Suggested Repair
If the battery is failing, replace it and fully charge the new battery before installation. On this Saturn, the battery powers the vehicle systems while the alternator recharges it.
Conversation Summary
The owner of a 2000 Saturn SL1 with about 123,900 miles reported a very low idle that nearly stalled at startup and when coming to a stop, and already knew a new battery was needed. The expert said the battery powers the car while the alternator only recharges it, and recommended replacing a failing battery after fully charging it. The owner later said the idle had returned to normal but still planned to replace the battery.
