1999 Saturn SL2 Cold Idle Pulsates
1999 SATURN
C404FLYER
I have a 99 saturn sl2. When its cold. Usually 35 degrees or less. When started it runs a few seconds then start to pulsate a few hundred rpm's. After it warms up it idles fine. Also on occasion if you shut it off and let it sit about 30 min to an hour and try to start, it acts like it flooded. Had it in the shop and they said no codes came up.
Mar 9, 2007 at 10:09 AM
PEPPERMRJ
  • 1,158 POSTS
The coolant temp sensor controls the input for the fan, gauge, and has a good deal to due with the air fuel ratio. this in turn can present poor fuel mileage, high idle, and hard/no start conditions.
The original ECTS from Saturn had a composite tip (plastic). They were known to fail after a period of time. Mine lasted around 100,000 mile on my 96 SC2.
Replace it with an updated brass tip model from saturn.
Pretty simple swap. Just like replacing a spark plug. Check the wire conector for corosion and clean or replace as needed.
Good luck and let us know. :)
Mar 11, 2007 at 2:26 PM
Suggested Repair
Replace the engine coolant temperature sensor with an updated brass-tip Saturn unit, and inspect the wiring connector for corrosion; clean or replace it if needed.
Conversation Summary
A 1999 Saturn SL2 pulsates a few hundred RPM when started in cold weather around 35 degrees or below, then idles normally once warm. After sitting 30 to 60 minutes it can sometimes act flooded, and a shop found no codes. The expert attributes this to a failing coolant temperature sensor, noting original composite-tip sensors commonly fail and affect air-fuel mixture, idle, and starting. They recommend replacing it with an updated brass-tip sensor and checking the connector for corrosion.
