1998 Saturn SL2 High Idle Speed
SATURN
EIGEROGRE
My 98 sl2 auto trans 58000 mi goes 25 without a foot on the pedal.took it to a local mech.He checked for vaccum leaks,found none,replaced idle air control. problem not solved.What now?
Oct 11, 2007 at 12:18 PM
CARUNDELL
  • 602 POSTS
[quote:31c40187c2="eigerogre"]My 98 sl2 auto trans 58000 mi goes 25 without a foot on the pedal.took it to a local mech.He checked for vaccum leaks,found none,replaced idle air control. problem not solved.What now?[/quote:31c40187c2]
Hey eigerogre,
I'm assuming your check engine light is on, was the vehicle scanned? If so what was the code? If there were no codes. Then I would recommend one more thorough vacuum leak check, then off to the dealership for a reflash of the PCM (a common issue with Saturns and idle issues) Let me know!
Chris
Oct 12, 2007 at 11:59 PM
EIGEROGRE
[quote:b72408cd6a="carundell"][quote:b72408cd6a="eigerogre"]My 98 sl2 auto trans 58000 mi goes 25 without a foot on the pedal.took it to a local mech.He checked for vaccum leaks,found none,replaced idle air control. problem not solved.What now?[/quote:b72408cd6a]
Hey eigerogre,
I'm assuming your check engine light is on, was the vehicle scanned? If so what was the code? If there were no codes. Then I would recommend one more thorough vacuum leak check, then off to the dealership for a reflash of the PCM (a common issue with Saturns and idle issues) Let me know! Hey Chris..
No light ever came on.no scan was done.By reading this forum,I replaced the coolant sensor with brass tip,old was cracked and plastic.....PROBLEM SOLVED! my saturn idles great and gets better mileage.My hat is off to your forum and writers ..Thank You.
Chris[/quote:b72408cd6a]
Oct 16, 2007 at 3:22 AM
CARUNDELL
  • 602 POSTS
[quote:bf584d1ef6="eigerogre"][quote:bf584d1ef6="carundell"][quote:bf584d1ef6="eigerogre"]My 98 sl2 auto trans 58000 mi goes 25 without a foot on the pedal.took it to a local mech.He checked for vaccum leaks,found none,replaced idle air control. problem not solved.What now?[/quote:bf584d1ef6]
Hey eigerogre,
Hey Chris..
Chris[/quote:bf584d1ef6][/quote:bf584d1ef6]
Thats Great! Thanks for the update!
Chris
Oct 16, 2007 at 4:14 AM
Suggested Repair
Replace a cracked coolant temperature sensor (plastic tip) with a brass-tip sensor. If the high idle remains, scan for codes, recheck for vacuum leaks, and consider a PCM reflash.
Conversation Summary
A 1998 Saturn SL2 automatic with 58,000 miles idled high enough to reach about 25 mph without pedal input. A mechanic found no vacuum leaks and replaced the idle air control valve without success. There was no check engine light and no scan. The owner later replaced a cracked plastic-tip coolant temperature sensor with a brass-tip sensor, which restored normal idle and improved mileage. The expert had suggested another vacuum-leak check and a PCM reflash if no codes were present.
