High Idle Speed
SATURN
SGTKEVINBROWN
Saturn
SL2
1.9 L4
5 speed manual
-At first start up Idle is above 2500 for over 5 mins.
-If you are sitting on a hill and just allow it to roll rpm go from 900 to 1700
-when shifting rpm don't drop unless you wait for aprox 15 seconds then drop to 1500 to 1700 only
-engin speed does not go below 1500 unless car is stoped for a 30 seconds to 1 min.
-checked codes and found none
-have auto xray diagnistic tool and viewed real time data and found no problems with TPS
-can not find a price for fuel pressure regulator anywhere does it have one?
-thinking Idle Air Control Valve
am i right?
this is a repair i am doing for a church at no cost need to try to spend as little as possable can you help?
Jan 25, 2007 at 7:58 AM
SERVICE WRITER
  • 9,123 POSTS
IAC i very possible. EGRs are a sore spot with these cars too. Clean em both.
Jan 25, 2007 at 10:03 AM
PEPPERMRJ
  • 1,158 POSTS
Coolant temp sensors are known problems and will cause high idles/ Easy and cheap fix. Get the updated brass tip design from saturn. Also check the wiring plug for corrosion. Clean or replace it also.
Good luck and let us know. :)
Feb 7, 2007 at 11:03 AM
SERVICE WRITER
  • 9,123 POSTS
[quote:e20693b93a="peppermrj"]Coolant temp sensors are known problems and will cause high idles/ Easy and cheap fix. Get the updated brass tip design from saturn. Also check the wiring plug for corrosion. Clean or replace it also.
Good luck and let us know. :)[/quote:e20693b93a]
Geez...I should have known better...I'm with you on that Peppermrj!
Feb 7, 2007 at 12:07 PM
