code 13 O2
1913 SATURN
JUANCBX3
  • 30 POSTS
Tested the 02 but stays at .800-.878 and dosent drop to .300 dont know why but i replaced the 02 and the check engine goes on still
Feb 16, 2006 at 8:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
There is more than one oxygen sensor. You will need to test them all no matter which one the code is pinpointing to be at fault. If all sensors are OK, flow test the catalytic converter. A clogged/faulty converter will also throw an O2 sensor code..
Thanks for using 2CarPros.com!
Mar 4, 2009 at 1:37 AM
