2002 Saturn SL2 P0446 EVAP Code
2002 SATURN
JUNKYARD
My car is a 2002 SaturnSL2 with 25000 miles on it,
Its hardly broke in. Engine trouble light came on, had code read PO446 ( Evaporative Emission Control System Vent Control Circuit malfunction) About two weeks prior to this when I went to gas up I noticed the gas cap was just lying loose inside the gas cover. I thiught this may have happened when my wife gassed up. I replaced the cap reset the cars computer but the next day the code was back... help
Aug 20, 2006 at 7:39 AM
MIKEYBDMAN
  • 623 POSTS
[quote:78001bb2d1="junkyard"]My car is a 2002 SaturnSL2 with 25000 miles on it,
Its hardly broke in. Engine trouble light came on, had code read PO446 ( Evaporative Emission Control System Vent Control Circuit malfunction) About two weeks prior to this when I went to gas up I noticed the gas cap was just lying loose inside the gas cover. I thiught this may have happened when my wife gassed up. I replaced the cap reset the cars computer but the next day the code was back... help[/quote:78001bb2d1]
Well, without having the proper scan tool, it is just a guess as to the problem. It could be a Fuel tank pressure sensor, a EVAP vent solenoid, or some kind of obstruction.
Check the following for causes of a blocked vent system:
EVAP vent solenoid blocked or stuck valve
Vent hose plugged, kinked or pinched
EVAP canister restricted
Aug 20, 2006 at 11:46 AM
Suggested Repair
Use a proper scan tool for a firm diagnosis. Check the EVAP vent solenoid for a blocked or stuck valve, inspect the vent hose for plugs, kinks, or pinches, and check the EVAP canister for restriction. A fuel tank pressure sensor is also a possible cause.
Conversation Summary
The owner of a low-mileage 2002 Saturn SL2 has a P0446 evaporative emission vent control circuit code. A loose gas cap was found and replaced and the computer was reset, but the code returned the next day. The expert says a proper scan tool is needed for a definite diagnosis and lists possible causes: a fuel tank pressure sensor, an EVAP vent solenoid, or a blocked vent path from a stuck solenoid, kinked or plugged vent hose, or restricted EVAP canister.
