I cannot pass my emissions test because my vehicle speed sensor is malfunctioning. I have had it replaced and have done the cold start, drive cylcles, and even had the code cleared. Previous to having the sensor replaced my Service Engine soon light had been on. Once I had replaced the sensor the light went off. It stays off until the service station plugs my computer in to run an emissions test. Once plugged in the Service Engine soon light comes on and I fail emissions. I get a P0500 code and sensors that previously read 'ready' on the test now read 'not ready' (Catalyst. Evap Sys, O2 sensor, and EGR sys) Is there anything more I can do to get this sensor to read right? Should I replace it again?
1998 Saturn SL P0500 Speed Sensor
Suggested Repair
Scan vehicle speed while driving above 3 mph to check for an intermittent VSS signal. Tighten the VSS to 20 ft-lbs, then measure 800-1600 ohms at the sensor terminals and on the wires to the PCM. If those checks pass, the PCM may be faulty and resetting the monitors.
Conversation Summary
A 1998 Saturn SL fails emissions with P0500 after the scan tool is connected, even though the VSS was replaced, codes were cleared, and about 200 miles were driven with the Service Engine Soon light off. Connecting the tester turns the light on and sets catalyst, EVAP, O2, and EGR monitors to not ready. The expert says a normal drive cycle is about 40-50 miles, then recommends checking live speed above 3 mph, VSS torque and resistance, wiring resistance to the PCM, and considering a bad PCM if those tests pass.
