2004 Saturn L300 Transmission Fluid in Oil
SATURN
ROB9999
whats the worst that can happen if i put the transmission fluid where the engine oil should go?
(only 1 quart)
i have a 2004 saturn L300 it has 51,000 miles
:shock:
Mar 29, 2006 at 6:54 AM
PEPPERMRJ
  • 1,158 POSTS
In the old days that was considered a way to remove sludge. Not at all necessary with modern oils. I doubt if you will see any real problems as long as you change it ASAP.
good luck and let us know. :)
Mar 29, 2006 at 7:51 AM
Suggested Repair
Change the engine oil as soon as possible. One quart of transmission fluid mixed with the oil is unlikely to cause real problems if the oil is changed promptly.
Conversation Summary
The owner of a 2004 Saturn L300 with 51,000 miles accidentally added one quart of transmission fluid where the engine oil goes and asked what harm it could cause. The expert said this was once used to remove sludge but is unnecessary with modern oils, and serious problems are unlikely if the oil is changed as soon as possible.
