1913 Saturn Code 13 O2 Sensor
1913 SATURN
JUANCBX3
  • 30 POSTS
Tested the 02 but stays at .800-.878 and dosent drop to .300 dont know why but i replaced the 02 and the check engine goes on still
Feb 16, 2006 at 8:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
There is more than one oxygen sensor. You will need to test them all no matter which one the code is pinpointing to be at fault. If all sensors are OK, flow test the catalytic converter. A clogged/faulty converter will also throw an O2 sensor code..
Thanks for using 2CarPros.com!
Mar 4, 2009 at 1:37 AM
Suggested Repair
Test all oxygen sensors, not only the one indicated by the code. If every sensor tests OK, flow-test the catalytic converter, because a clogged or faulty converter can also set an O2 sensor code.
Conversation Summary
The owner of a 1913 Saturn reports code 13 and an oxygen sensor voltage that stays around 0.800-0.878 and does not drop to 0.300. Replacing the O2 sensor did not turn off the check engine light. The expert advises testing every oxygen sensor regardless of which one the code points to, then flow-testing the catalytic converter if the sensors are OK.
