1997 Saturn SC1 Hard Steering Battery Light Fix
SATURN
SOYLESLEY
1997 Saturn SC1, 165,000 miles - I noticed my battery light was on when I started my car and it was difficult to steer. I checked the level of power steering fluid and it was fine. Do you know what's possibly wrong.
May 7, 2006 at 10:22 AM
LOSONE
  • 1,616 POSTS
The battery light has nothing to do with your power steering.
Battery light is probably an alternator
Hard steering is probably the rack and pinion unless it has a separate belt and then it could be the belt
May 7, 2006 at 10:28 AM
PEPPERMRJ
  • 1,158 POSTS
[quote:b6bf77bb30="soylesley"]1997 Saturn SC1, 165,000 miles - I noticed my battery light was on when I started my car and it was difficult to steer. I checked the level of power steering fluid and it was fine. Do you know what's possibly wrong.[/quote:b6bf77bb30]
It is unlikely that both units failed simultaneously. Chances are your serpentine belt and it's tensioner are either dead or dying. I would replace both.
Good luck and let us know. :)
May 7, 2006 at 3:18 PM
Suggested Repair
Inspect and replace the serpentine belt and its tensioner, since a failing belt can cause both the battery light and hard steering. If the battery light remains, have the alternator checked.
Conversation Summary
The owner of a 1997 Saturn SC1 reported a battery light and difficult steering despite a normal power steering fluid level. One expert said the light likely points to the alternator and the hard steering to the rack and pinion or a belt. Another said both symptoms are unlikely to be separate failures and recommended replacing the serpentine belt and tensioner.
