1997 Saturn SC1 Vibrates When Braking
SATURN
TABEL
1997 Saturn SC1, 55K miles: In the last couple months I've noticed that when I put on the breaks at speeds over 30 MPH, my steering wheel starts to vibrate or shake. What's causing this and how much will it cost to fix it?
Feb 22, 2006 at 2:02 PM
PEPPERMRJ
  • 1,158 POSTS
Sounds like you may have a warped brake rotor or two, or three, or even four.
Prices can vary greratly depending on what part of the world you are in and what actually needs repaired or replaced.
Rotors can be trued on a brake lathe if they are thick enough for under $10.00 US apiece. They can be purchased (aftermarket) for under $30.00 each in my neck of the woods. Labor should be similiar to having the brakes pads replaced.
God luck and let us know. :)
Feb 23, 2006 at 4:48 AM
PEPPERMRJ
  • 1,158 POSTS
I forgot to mention that you should always have the steering and suspension components checked during a brake service. A lot of places will do this free of charge or for a very small fee. Always a good safety measure, for sure.
Feb 23, 2006 at 4:51 AM
Suggested Repair
Inspect the brake rotors for warping. If they are thick enough, have them resurfaced on a brake lathe; otherwise replace them. Also have the steering and suspension components checked during the brake service.
Conversation Summary
A 1997 Saturn SC1 owner reports steering wheel vibration when braking above 30 mph and asks about the cause and repair cost. The expert attributes it to one or more warped brake rotors, notes that rotors may be resurfaced if thick enough or replaced, and recommends checking steering and suspension during the brake service. Cost varies by location and the parts and labor required.
