1999 Saturn SL CV Boot Noise When Turning
SATURN
RBN_JOHNSON
I have a 1999 Saturn sl. with 126118 miles on it. When I turn the steering wheel to the right I hear a sound that just wasn't there before I can also feel it. I was told that I needed to get new cv boots. What are cv boots and how can I tell if and when I need new ones
May 30, 2006 at 1:50 PM
SYNCRAIT
  • 235 POSTS
if you look behind the front tires you will see a shaft that turns the wheel.... that is the cv shaft... on either side of the cv shaft there are rubber boots to protect the knuckle and to keep the grease in when the boot rips the knuckle more or less dries up and wears out much like a bad knee.... if its ripped replace it....
May 31, 2006 at 11:47 AM
Suggested Repair
Inspect the CV axle boots behind the front wheels. If a boot is ripped, replace it so the joint does not lose grease and wear out.
Conversation Summary
The owner of a 1999 Saturn SL with about 126,000 miles hears and feels a new noise when turning the steering wheel right and was told the CV boots need replacement. The expert explains that the boots cover the CV joints, keep grease in, and should be replaced if ripped.
