Saturn SC1 2002. Battery or electric system?
2002 SATURN
QAYAQPUMA
Hi. this is my problem. I got a 2002 Saturn SC1 about 3 years ago. So far so good. No problems whatsoever... but today things changed. I went to a grocery store and when I came back out the car didn't start. Not the radio nor the headlights got on and only the Service Engine light and the Security lights went on on the dashboard. I got the car jump started and it went ok but not for very long. Suddently the needle of the gas started to go down and down and down (which is weird because the car had more than half a tank) and all the other lights went also on on the dashboard. Finally when the gas needle was all the way down the car went off. We jump-start it again and it keep going ok til I got to my friend's house. I tried to start it there and nothing happened. So I got it jump-start it again and it worked again. The guy that put help me out with the jump starting deal said that there was a lot of corrosion on the battery ports and that if I wash them it will help. I will do that tomorrow but I'm getting worried cause I don't know if the problem is only the battery or also the electical system... Can somebody help me out? Do you think is the battery or something else? Thanks.
Feb 18, 2006 at 6:00 PM
FISHERMAN
  • 937 POSTS
start cleaning the battery posts and connectors and be sure that its making a solid good connection, that could be your problem.
Feb 19, 2006 at 6:58 AM
NICK DECOCK
I agree with the cleaning the battery and terminals but i would also put a voltmeter on your battery while you have it started to see if you have your 12.5 to 14 volts. If you dont than it is an alternator,or a blown fuse. But you can have the battery and alt. tested at a local parts store and they can tell you if any are bad or going out. Good Luck!!
Feb 28, 2006 at 3:11 PM
Suggested Repair
Clean the battery posts and cable connectors so they make a solid connection. With the engine running, check battery voltage; it should be about 12.5 to 14 volts. If voltage is low, suspect the alternator or a blown fuse, and have the battery and alternator tested at a parts store.
Conversation Summary
The owner of a 2002 Saturn SC1 reported a no-start with only the service engine and security lights on. After jump-starts, the fuel gauge dropped and the car stalled. Corrosion was noted on the battery terminals. Experts advised cleaning the posts and connectors, checking running voltage at about 12.5 to 14 volts, and having the battery and alternator tested, including a possible blown fuse if voltage is low.
