1998 Saturn SC1 Radiator Leak
Depending on the mileage the leak could also be elswhere. My waterpump went @ about 115,000 miles. Stop leak won't be effective.
There is a down side to stop leak products also. In some instances they have been thought to clog heater cores.
If you can determine that the leak is from the center of the rad in the aluminum rows go for it. Follow the product instructions and turn the heater off maybe even to AC and cold temperature setting.
Good luck and let us know. :)
Suggested Repair
Locate the leak before using stop-leak. It may seal the aluminum radiator core but will not seal cracked plastic side tanks or a failed water pump, and it can clog the heater core. If the leak is in the aluminum core, follow the product instructions and keep the heater off or set the temperature to cold.
Conversation Summary
The owner of a 1998 Saturn SC1 reports antifreeze leaking, a flashing dash warning light, a reservoir that will not hold coolant, and wetness under the car, and asks whether stop-leak can be used temporarily. The expert says stop-leak may work on the aluminum radiator core but not plastic side tanks or a water pump, warns it can clog the heater core, and advises following the product instructions with the heater off if the leak is in the aluminum rows.
