1996 Saturn SC1 Misfire After Head Repair
Suggested Repair
If a multicylinder misfire remains after head replacement, check compression before assuming the timing chain is off. On this car, cylinder 4 had no compression because the intake rocker was not seated correctly and the valve stayed open. Realign the rocker so the valve closes, then recheck. Also verify plug-wire order and inspect the intake manifold and hoses for vacuum leaks.
Conversation Summary
A 1996 Saturn SC1 was using oil and leaking it from the radiator overflow. After the cracked cylinder head was replaced and the cooling system flushed, it had a P0300 multicylinder misfire. The owner asked whether the timing chain might be one tooth off. An expert doubted a timing error and suggested checking plug-wire order and looking for vacuum leaks. Compression testing then showed zero compression in cylinder 4. The intake rocker on the new head was misaligned, leaving the valve open. After the rocker was tapped into place and the valve closed, the misfire stopped and the check-engine light went out.
