1993 Saturn SC2 Won't Upshift Into Drive
1993 SATURN
HILLING
i have a 93 saturn SC 2 1.9L DOHC it has 105024 miles on it was running good in tell to day. i was driving it home and i slowed down for the light and it down shifted fined but i would not shift back up in to drive. you can come to a stop and if shift up fine in tell you get to drive.
Apr 26, 2007 at 4:44 PM
2CARPRO JACK
  • 11,533 POSTS
Is the check engine light on? If it is then have it scanned. If the PCM had a problem with something it will have stored a code, giving us a place to start
Apr 27, 2007 at 1:09 AM
HILLING
i was told it might be a solenoid in the trans.
Apr 27, 2007 at 9:20 AM
PEPPERMRJ
  • 1,158 POSTS
Very likely. Saturn S-series trannies are unique in that they share features of a regular automatic transmission and aslo those of a manual tranny such as the gears being "shifted" by the solenoids.
Good luck and let us know. :)
peppermrj
Apr 27, 2007 at 11:04 AM
Suggested Repair
If the check engine light is on, scan the PCM for stored codes. A failed transmission shift solenoid is a likely cause, since Saturn S-series automatics use solenoids to shift gears.
Conversation Summary
The owner of a 1993 Saturn SC2 1.9L DOHC with about 105,000 miles says the automatic transaxle downshifts normally but will not shift back up into drive until the vehicle is stopped. One expert recommends scanning for codes if the check engine light is on. Another agrees a transmission solenoid is likely and notes that S-series transmissions shift gears with solenoids.
