1995 SC2 Transmission
1995 ALL OTHER MAKES ALL OTHER MODELS
HPDORMAN
Hello - I have a 95 SC2 with 133,000 miles, 4 spd auto tranny.
About a month ago, I started having transmission problems. The reverse gear works OK the car is cold, but when warmed up it will only go backwards when it is revved very high in reverse (about 6000 rpm) and then it only backs very slowly.
Also, the Service Engine Soon light comes on when it first shifts from 1st to 2nd and stays on, and often from 1st to 2nd it is a hard shift. Other than that, no problems with all 4 forward gears..
I read online that this was likely the Transmission Valve Body, so I bought a used one on-line and installed it but I still have the same problem.
What else could be causing these problems, or did I just get another bad Valve Body?
Thanks! Harry, Appleton WI
Jan 7, 2007 at 12:20 PM
SERVICE WRITER
  • 9,123 POSTS
Hi Harry,
What code is stored the the computor?
Jan 7, 2007 at 12:22 PM
HPDORMAN
[quote:41e1d0d381="Service Writer"]Hi Harry,
What code is stored the the computor?[/quote:41e1d0d381]
I don't know - how do I find out? HD
Jan 8, 2007 at 4:23 AM
SERVICE WRITER
  • 9,123 POSTS
Best bet is to buy a code reader. If not autozone may do it for free. The is a diagnostic connector under the dash.
Jan 8, 2007 at 11:25 AM
SEARS1
Harry, dont feel alone...Im having the EXACT same problem? I forgot what code the mechanic pulled, something dealing with a 1st to 2nd shift...he wanted me to have the tranny rebuilt...Im holding off for maybe a cheaper repair
Feb 5, 2007 at 11:57 PM
2CARPRO JACK
  • 11,533 POSTS
We have fixed a few with a new valve body, have the codes checked to be sure.
Feb 6, 2007 at 12:06 AM
SEARS1
I had a mechanic read the code, I forgot what he said, but it something like a first to second gear shifting problem.....in which I already knew that....could the valve body affect some gears and not others?
Feb 6, 2007 at 12:11 AM
2CARPRO JACK
  • 11,533 POSTS
Absolutely. Uses electric solenoids to shift
Feb 9, 2007 at 1:35 AM
