1995 Ford F-150 Transmission Fluid Low
I would take it back apart and make sure the passages are not obstructed with the new filter.
If you are not framiliar with transmissions, it may be best to take it to the pros. I do know you need to fix this before you do major damage to an expensive part of the car.
My practice is I always pay the $100 for tranny services. So far Aamaco has never let me down.
Good luck, and let us know what the problem was...
E4OD: W/4x2 15.7 qt (US)
W/4x4 16.2 qt (US)
i called 2 different ford dealers today and they told me the 2 different things... the first guy said they only put 3-4 quarts in after a filter change.
the 2nd guy said get it hot and fill it until it's full
now i'm wishing i would have taken it some where!
Think back to when you dropped the pan....was it like pouring three quarts of oil, or like pouring three gallons of milk?
Think back to when you dropped the pan....was it like pouring three quarts of oil, or like pouring three gallons of milk?[/quote:9ed140929a]
it was quite a bit of fluid! alot more than 3-4 quarts
Suggested Repair
Check the E4OD fluid level with the transmission hot and the engine idling in Park, then add fluid until the dipstick is in the normal range. A high reading with the engine off and cold is normal. A filter and pan service can require more than 5-6 quarts if a large amount drained; total 4x4 capacity is about 16.2 quarts. If the hot level will not come up, recheck that the new filter is not blocking the passages.
Conversation Summary
The owner of a 1995 Ford F-150 4x4 changed the E4OD transmission filter. After adding 6 quarts, the hot idle-in-Park reading was still low, while the cold engine-off reading was halfway up the crosshatch. Experts said a high cold reading is normal, cited about 16.2 quarts total capacity for a 4x4 E4OD, and advised filling to the correct level only when hot. The owner confirmed that far more than 3-4 quarts had drained from the pan.
