2001 Saturn SC2 38,000 miles - clutch problem
2001 SATURN
LIBBY2001
The gears were a bit sticky, then suddenly the clutch was almost all the way to the floor. I took it in for repairs and was told it needed a new clutch. Got the new clutch. However, when I got the car back, although the gears are smoother, the clutch is still almost all the way to the floor. Also, the car had a new clutch a couple years ago due to a common bad clutch problem with this model. It would wait a second or two or three after releasing the clutch before engaging and continuing to move forward. Two questions: Are the clutches in Saturns really so bad that they have to be replaced this often? Shouldn't a new clutch be stiffer and not still be almost to the floor?
May 19, 2007 at 2:38 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a hydraulic problem. Might want to find another tech for a second opinion. I have seen those clutches go 100k
May 20, 2007 at 12:53 AM
SERVICE WRITER
  • 9,123 POSTS
I'll second Jack on that. Sounds like a possible slave cylinder leakage problem.
May 23, 2007 at 2:08 PM
