1993 Other Saturn Models clutch doesn't work
1993 SATURN
100,000 MILES • 4 CYL • 2WD • MANUAL
SSUE_542000
Please help. My grandson has a 1993 Saturn and I stepped on the clutch and it goes all the way to the floor, with no resistance and the car will not go forward when I step on the gas. The shifter will not move. Is the cable broken or is there a hydralic problem
Thanks Sue
Dec 29, 2007 at 5:58 AM
Its hydraulic operated-for a start check the clutch master cylinder if it has fluid none or low - fill it and bleed the system.
Dec 29, 2007 at 6:06 AM
SSUE_542000
Thank you for your answer. We will try that. The other options I have been given are a repair shop that says repairs could be from 350 to 800 dollars.
Thanks again this is very much appreciated.
Nanny Sue
Dec 30, 2007 at 4:51 AM
