1997 Saturn SL2 Loses Power While Driving
1997 SATURN
JENNA33
I have a 1997 Saturn SL-2 and I do believe that I need a new alternator. I just replaced the water pump, idler pulley, and a new battery. When driving all power is lost and it shuts down. I can get it jumped but can not step on the brakes or it shuts down. However, if I put the car in drive before I take off the cables I can drive it. Any suggestions or info would be greatly appreciated. Thank you!
Apr 20, 2007 at 5:28 AM
PEPPERMRJ
  • 1,158 POSTS
Hey Jenna,
First make sure your serp belt and it's tensioner are in good shape. Is the alt light on solid?
Chances are it is bad and does need rebuilt or replaced. I can link you to specific instructions if you need them.
Good luck and let us know. :)
peppermrj
Apr 23, 2007 at 2:39 PM
JENNA33
I just wanted to update. It was the alternator and I did get it changed out. It was quite simple, although odd that I had to go through the front right wheel well. Anyhow thank you again for the response. :D
Apr 23, 2007 at 3:54 PM
PEPPERMRJ
  • 1,158 POSTS
Cool. Thanks for the update. Front wheel drive cars are like that.
peppermrj
Apr 24, 2007 at 3:29 AM
Suggested Repair
Check the serpentine belt and tensioner, then rebuild or replace the alternator. The confirmed fix was an alternator replacement, accessed through the right front wheel well.
Conversation Summary
A 1997 Saturn SL2 lost all power and shut down while driving after a new battery, water pump, and idler pulley. It could be jump-started but died when the brakes were applied unless left in drive before the cables were removed. The expert advised checking the serpentine belt and tensioner and said the alternator likely needed rebuilding or replacement. The owner later confirmed the alternator was the cause and that replacing it fixed the problem.
