1997 Saturn SL2 Coolant Warning Lights
1997 SATURN
MARK62
Saturn SL2 1997 Manual, 1.9L Over100,000 miles.
The problem is The bottom two warning lights on the right side blink on and off after driving for a short period. The light look like they have something to do with water temp and water level. System is fill and temp is in the middle of gauge. We dont have the owners book to tell what the lights are or mean.
Thank you
Sep 26, 2007 at 4:35 PM
SERVICE WRITER
  • 9,123 POSTS
Sounds like the coolant level and temperature as you thought. Theses are common for bad coolant temperature senders cracking. Often there is accompanied problems such as runnability problems, starting problems or check engine light. However I would address this asap.
Sep 28, 2007 at 6:44 AM
SERVICE WRITER
  • 9,123 POSTS
Soooooo...What happened?
Oct 2, 2007 at 1:08 PM
MARK62
Changed the coolent bottle assembly
Oct 6, 2007 at 10:07 AM
Suggested Repair
Inspect and replace a cracked coolant temperature sender, which commonly causes these warnings, and verify the coolant level sensor. The owner reported replacing the coolant bottle assembly.
Conversation Summary
A 1997 Saturn SL2 with over 100,000 miles had the two lower right warning lights, believed to be coolant temperature and level, blinking after a short drive even though the coolant was full and the gauge was normal. The expert said cracked coolant temperature senders are a common cause and should be addressed promptly, especially if starting, running, or check-engine issues appear. The owner later reported replacing the coolant bottle assembly.
