1993 Other Saturn Models warning electrical light
1993 SATURN
163,000 MILES • 4 CYL • FWD • AUTOMATIC
DAN7
the electrical warning light came on the dash that looks like a battery...& the battery ended up dying. i thought it might be the alternator, but i checked the battery & it was low on water so i added some water to it & charged it up on a battery charger. i then put it back in the car & the car started & appears to hold a charge. But the warning light is still on so my question is whether the indicator needs to be reset somehow or if there is still a problem with the electrical system?
Jun 11, 2008 at 9:33 PM
LEGITIMATE007
  • 5,121 POSTS
Im gonna give you some simple tests to do for your alternator and battery, also; bad connections or corroded connections will also cause the same problem, so you'll have to check those too. Your alternator may not be chargeing correctly so check out these tests:
Jun 11, 2008 at 10:06 PM
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/how_to/test_alternator.htm
this will show you how to test your alternator
LEGITIMATE007
  • 5,121 POSTS
this test is pretty much the same as the alt. but its for the battery test.:
https://www.2carpros.com/how_to/battery.htm
Jun 11, 2008 at 10:07 PM
