1995 Saturn SL2 Key Stuck in Ignition Fix
SATURN
PRIC0166
I bought a used car (1995 Saturn SL2) and was provided with a spare key. I used this in the door, then the ignition, and it worked in both and even started the car; however, now the key is stuck in the ignition. I can't turn the key back past battery access in order to remove it; the radio shows a messasge that says "lock" and my battery is being permanently drained.
Will I need to replace the ignition or is there some way to get this key out?
Sep 2, 2007 at 3:15 PM
  • 31,937 POSTS
Hi there,
I feel that it would save a heap of grief if you got a new lock and key, if you do get the stuck key out. the lock may be damaged internally and you could be looking at the same problem again, go for a new lock and key.
Mark (mhpautos)
Sep 2, 2007 at 4:08 PM
Suggested Repair
If the stuck key can be removed, replace the ignition lock and key. The lock may be damaged internally and the same problem can return.
Conversation Summary
The owner of a 1995 Saturn SL2 used a spare key that worked in the door and ignition and started the car, but the key is now stuck and will not turn back past accessory so it can be removed. The radio shows lock and the battery is draining. The expert advises replacing the lock and key because the lock may be damaged internally and the problem could recur.
