2001 Saturn L100 Ignition Lock Won't Turn
Have you tried turning the steering wheel both ways. Sometimes that is all it take. It can require some muscle tho.
Good luck and let us know.
Suggested Repair
Try turning the steering wheel firmly both ways to relieve binding so the key can move. The lock cylinder is typically released by a pin depressed with the cylinder in the run position; confirm whether only the plastic housing or the steering wheel must come off in a Haynes or Chilton manual. Do not disturb airbag components without the proper procedure.
Conversation Summary
The owner of a 2001 Saturn L100 cannot turn the key and cannot remove the ignition lock cylinder. The expert said a release pin is usually depressed with the cylinder in the run position, was unsure whether the steering wheel or only the plastic housing must be removed, and recommended a Haynes or Chilton manual plus caution around airbags. They also suggested turning the steering wheel both ways, which can take some force.
