1995 Other Saturn Models electrical problem
1995 SATURN
MIRIN
Electrical problem
1995 Other Saturn Models 6 cyl Front Wheel Drive Manual
in the last 6 years the car has run through multiple alternators starters and batteries we took it in to be repaired but the could not find any thing wrong except that the amperage from the alternator was only in the 20-30 range when it should be in the80 bto 100 range the voltage and every thing else check out and all the grounds are working okay to do you have any ideas on what the problem might be?or how to fix it?
May 21, 2008 at 6:14 AM
  • 75,988 POSTS
that the amperage from the alternator was only in the 20-30 range when it should be in the80 bto 100 range the voltage.
Where this reading taken at curb idle or up to 2K rpms while being tested?
May 21, 2008 at 10:30 AM
MIRIN
it was tested at both also sine the alternator starter and battery also the grounging wires were checked and they are all in good order
Aug 9, 2008 at 10:55 AM
