1997 Other Saturn Models How to Clean a Ground
1997 SATURN
145,000 MILES • 4 CYL • FWD • MANUAL
ERIC996
I believe that the ground in my left body splice pack may be the cause of my car only clicking when I turn the key (I brought it to the mechanics and after around 4 hours they said that the ground is bad on this splice pack)
I know I should pull it out and sand it down, but far as for cleaning, do I use a certain type of solution?
May 4, 2008 at 9:27 AM
MASTERTECHTIM
  • 4,750 POSTS
if its a bad ground on a splice pack most likely the ground end will need to be cut off and a new eye crimped on. sand the ground area with sand paper and reinstall.
May 4, 2008 at 9:40 AM
ERIC996
Should I pull the whole ground out of the splice pack, or just take off the cover and sand the exposed metal?
May 4, 2008 at 9:43 AM
MASTERTECHTIM
  • 4,750 POSTS
i always find it will be green inside, thats why i cut it out and make my own connection.
May 4, 2008 at 9:48 AM
