2006 Lexus IS Acceleration Rumble
169,200 MILES • 3.5L • AUTOMATIC
MLPARR
I’m looking for advice on how to diagnose this rumbling sound on my 2006 Lexus IS350. The noise has been happening for several thousand miles at this point and hasn’t been effecting the driveability of the car.
The sound never presents itself in park or neutral, only drive and reverse. The noise follows the RPMs of the car. The sound triggers when accelerating from a stop and rarely happens when at highway speed. (60+ mph) There is a vibration I can feel through the pedals and it seems to occur more often when the car is at an incline.
The car has 169K miles on it now and the previous owner, who said he was a mechanic, had told me that he replaced the transmission at 150k with the correct Toyota fluid. I recently performed a drain and fill while leveling the fluid correctly. I had a PO761 and P2714 code before the service, and now only the P2714 remains. The fluid was dirty but not to a level I would consider disastrous to the transmission.
The car drives perfectly fine despite the awful sound it makes. The transmission has gotten stuck in 3rd or 4th gear before but has been driving perfectly fine since then which was even before the service I did.
Would greatly appreciate some advice. Thanks.
Nov 3, 2026 at 2:24 PM
  • 55,781 POSTS
I would look under the car to see if the under valance is loose and rubbing on the ground. If you are good, I would check the rear transmission mount. I have also seen the driveshaft center mount go bad or be loose and cause this kind of noise. That bearing and its rubber support are worth inspecting for the acceleration rumble, along with the driveshaft couplings—especially following a transmission replacement.
Your codes are:
- P0761: Shift-solenoid “C” performance, identified by Lexus as solenoid S3.
- P2714: Pressure-control-solenoid “D” performance, identified as SLT. This is a performance fault, so it does not automatically mean the solenoid itself needs replacing; hydraulic or internal transmission problems can also cause it.
Nov 4, 2026 at 7:48 AM
Suggested Repair
Inspect the underbody valance for looseness or ground contact, then check the rear transmission mount, driveshaft center bearing and rubber support, and driveshaft couplings. Treat P2714 as a pressure-control solenoid performance fault that may be hydraulic or internal, not automatically a failed solenoid.
Conversation Summary
The owner of a 2006 Lexus IS350 with about 169,000 miles reports an RPM-related rumble and pedal vibration during acceleration in drive or reverse, mainly from a stop and on inclines, with no noise in park or neutral and no current drivability problem. A prior transmission replacement, a recent drain and fill, and codes P0761 and remaining P2714 were noted. The expert recommends checking a loose under valance, the rear transmission mount, the driveshaft center mount and rubber support, and the driveshaft couplings, and explains that the codes indicate shift-solenoid and pressure-control performance faults that are not automatically solenoid failures.
