2002 Honda Civic Acceleration Noise
RAJ.NORTH
I have a 2002 honda civic lx 1.7 L with 97K clicks, since last 2 months the engine is making more noise and gives a bit of vibration on raise and feels as if it is strugling (during acceleration in particular between 1500-3000 rpm), once past 3000 rpm the car drives smooth. I changed the spark plugs it still did not helped. any suggestions?
Jun 5, 2007 at 5:22 PM
BRUCE HUNT
  • 3,754 POSTS
What kind of noise are you getting? Is it more like an exhaust system noise? I would take some time to check the exhaust system. Drive the car up on a ramp and with the help of a friend have them hold a rag over the tailpipe to temporarily plug the pipe. You should be under the car noting where any exhaust leaks are. Start with that and while under there, examine the heat shields on the exhaust as well for any of them that might be loose.
Jun 6, 2007 at 1:33 AM
Suggested Repair
Inspect the exhaust system for leaks and loose heat shields. With the car safely raised, have a helper briefly cover the tailpipe with a rag while you check underneath for escaping exhaust and rattling shields.
Conversation Summary
The owner of a 2002 Honda Civic LX 1.7L reports increased engine noise, vibration, and struggling acceleration between 1500 and 3000 rpm, with smoother driving above 3000 rpm. Replacing the spark plugs did not help. The expert recommends checking the exhaust for leaks and inspecting the heat shields for looseness.
