1994 Honda Civic Weak Acceleration
KUKLOVOD
My Honda Civic 1994 suddenly stopped and couldn't start.I towed it to mechanic and they replaced the distributor and timing belt.The belt wasn't broken but they said it was jumping.I took it back and noticed there is no power. Sometimes It takes me 5-6 seconds to take off from idle.The mechanic said the compression will slowly rise because the injectors were dirty and I should put some fuel system cleaner in the tank when I fill it.After I read some of the forums I suspect that there may be bent valves.I wonder why the mechanic didn't check that and didn't tell me that.I paid so far $1500.How much is the average price for valve repair and is it worth it?Can I dispute the charge since I wasn't told about the complete problem of the car?Please Help!
Thank you :( :(
Jul 7, 2006 at 6:31 PM
RUNTICH
  • 27 POSTS
How does the car idle, like normal or eractic??
Jul 8, 2006 at 5:57 PM
KUKLOVOD
I stop at a stop light.I step on the gas pedal when green-nothing happens.After 5-6 sec very slowly it starts accelerating.After it shifts it looses power again.Seems like the engine is very weak.When in park position I turn on the A/C I can feel the vibrations of the engine shaking trying to supply it with power.It was running great before they change my timing belt,water pump, distributor,spark plugs and oil.
Jul 12, 2006 at 5:12 PM
BRUCE HUNT
  • 3,754 POSTS
Find someone with a timing light. I would be that thing is so far off time that you may not even see the timing marks on the balancer. This work was not done by Honda was it. I am not tauting their work but finding other good mechanics to work on them is tough.
Jul 13, 2006 at 8:49 AM
KUKLOVOD
I am bringing it next week to an official honda dealer service.It is strange that the car cruns perfect with cold engine.After 5 min of driving it starts the lack of power.It is strange.Thank you for the advice.if anybody else has any ideas I will appreciate it.
Jul 13, 2006 at 6:26 PM
Suggested Repair
Have ignition timing checked with a timing light. The timing belt and distributor work may have left the engine far out of time. A Honda dealer can verify the timing and related work.
Conversation Summary
A 1994 Honda Civic stopped and would not restart. A shop replaced the distributor and timing belt, saying the belt was jumping though not broken, and also replaced the water pump, spark plugs, and oil. Afterward the engine was weak, slow to accelerate, and lost power after shifting, though it ran better when cold. The owner suspected bent valves and asked about repair cost and disputing the bill. An expert advised checking ignition timing with a timing light, suspecting it was far off, and the owner planned to take the car to a Honda dealer.
