2002 Grand Prix Poor Acceleration
2002 ALL OTHER MAKES ALL OTHER MODELS
JM_LMX
My 02' Grand Prix has roughly 80,000 miles on it. For the past few months, I've been having problems with the car's acceleration. 90% of the time it stalls or takes an excessively long time to reach say 45mph. Going uphill it takes longer. Engine light has come on several times, and all I could get out of two mechanics was that a misfire was occurring along with other codes that they failed to notify me as to what exact codes they were. Also recently, a loud, high pitched whistle is coming from around the backside of the intake manifold. I've changed plugs and wires, changed fuel pump and filter, and I'm currently taking out fuel injectors to inspect for clog. Please help me narrow my search for problem down. I think I have to check catalytic converter, O2 sensors, coil pack and vacume hoses
Jan 21, 2006 at 12:15 PM
JPTRUAX
  • 18 POSTS
I would check for vacuum leaks, especially around the intake.
Jan 21, 2006 at 1:26 PM
JLIL
Heyy man, i hadd that EXACT same problem like 2 days ago!! I had changed my spark plugs N it didnt fix the problem BUT i when i went and got my fuel injectors pressured clean N whatever they did to clean em for like an 1 hour N a half... It FIXEEDD IT!!! Put dont take your fuel injectors off, i was going to take mines off ,but i find out you dont have to, the mechanic people puts them on an machine with them on.. Soo good luck hope it works for you like it did for me!! =)
Jan 24, 2006 at 1:05 PM
MVANNESSJR
  • 223 POSTS
Check IAC (Idle Air Control) and throttle body for carbon deposits while you are at it.
Jan 24, 2006 at 4:33 PM
Suggested Repair
Check the idle air control valve and throttle body for carbon deposits, and inspect for vacuum leaks around the intake manifold.
Conversation Summary
A 2002 Grand Prix with about 80,000 miles stalls or accelerates very slowly, especially uphill, and has a high-pitched whistle near the back of the intake manifold. The check-engine light has indicated a misfire, but the exact codes were not provided. Plugs, wires, the fuel pump, and the fuel filter were already replaced, and the owner was removing the injectors to check for clogs. Replies suggest checking intake vacuum leaks, having the injectors cleaned on the vehicle, and inspecting the idle air control valve and throttle body for carbon deposits.
