2000 Toyota Echo Fuel Line Disconnect Fix
2000 ALL OTHER MAKES ALL OTHER MODELS
CHARLIE9G
a bit stuck on this work. there are two gas lines going down into the fuel pump, a big one which must be the feed, and a small one which is the return i guess. the big line disconnects with a quick connector setup on the end, which i was able to do although i had never seen this type of setup before and you would expect some kind of clamp across the hose. the little line goes into its fitting which has a plastic sort of snap retainer which i was able to slide back easily. the small line is a quarter inch and seems fused on the end of the fitting with no external clamp. after sliding the retainer back i tried to turn the fitting on this and lift it up no luck. anyway, how does this small line which is the one toward the front of the vehicle disengage? thanks, chuck
Apr 15, 2006 at 11:22 AM
LOSONE
  • 1,616 POSTS
Both lines have a spring style disconnecxt. Go up the line a bit and see if it has one. If it has a clamp it is only a matter of forcing the hose off the hump in the line. Look at the new pump and see how it is made. Good luck
Apr 15, 2006 at 12:24 PM
Suggested Repair
Both fuel lines use a spring-style disconnect. Check farther up the small line for the disconnect. If a clamp is present, force the hose off the raised hump on the line, and compare the fittings with the new pump.
Conversation Summary
The owner of a 2000 Echo is stuck disconnecting the small front fuel line at the pump after sliding back its plastic retainer. The expert says both lines use a spring-style disconnect, advises looking farther up the line, and says a clamped hose can be forced off the fitting hump. Comparing the old fittings with the new pump is also suggested.
