2002 Ford Mustang Acceleration Miss
THE RAMP RAT
84k MILES........... MISSES WHEN ACCELERATING not when cruising never had plugs or wires..??? start here??
thanx Donnie O. 02 ford mustng 3.8L
Dec 17, 2006 at 2:08 PM
CARUNDELL
  • 602 POSTS
[quote:9ea56452d1="The Ramp Rat"]84k MILES........... MISSES WHEN ACCELERATING not when cruising never had plugs or wires..??? start here??
thanx Donnie O. 02 ford mustng 3.8L[/quote:9ea56452d1]
Hey donnie!
Would most definitely look a tune up. Is there also a check engine light on or flashing? let us know!
Chris
Dec 17, 2006 at 9:31 PM
THE RAMP RAT
AFTER REPLACING WIRES AND PLUGS ... STILL MISSED....PUT ON SCOPE TURNED OUT TO BE A BAD WIRE BLOCK (DISTRIBUTER) CAR NEVER HAD A CHECK ENGINE LT. BUT REPLACED AND RUNS GREAT.. DON O.
Dec 28, 2006 at 3:27 PM
Suggested Repair
Replace the distributor wire block. A tune-up with new plugs and wires did not stop the acceleration miss; a scope confirmed a bad distributor wire block, and replacing it resolved the problem.
Conversation Summary
A 2002 Ford Mustang 3.8L with 84,000 miles missed under acceleration but not while cruising and had never had plugs or wires replaced. The expert recommended a tune-up and asked whether the check engine light was on. After plugs and wires were replaced, the miss remained and there was no check engine light. A scope showed a bad distributor wire block; replacing it made the car run well.
