Not starting, could the remote start cause it to not start?
250,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
GARY FISH
  • 5 POSTS
will my remote start cause my car not to start
May 20, 2023 at 1:50 AM
  • 110,248 POSTS
If the vehicle has an aftermarket remote starter, yes, it can cause a no-start condition.
I need some general information to help. First, does the starter engage when you try starting and the engine fails to run? Or, when you turn the key to start, does the starter not engage? Is the anti-theft/security lamp staying on with the key on?
Let me know as much as you can. If it is an aftermarket system, I won't have the specific wiring schematics, but I will try to figure things out for you.
May 20, 2023 at 3:16 PM
GARY FISH
  • 5 POSTS
no, the starter does not engage if set for a day it starts and them. I play with the remote start in does not want to start at all.
May 21, 2023 at 10:41 AM
  • 110,248 POSTS
Gary,
If this is an aftermarket remote start, chances are that is the cause. Let me know if it is aftermarket. Also, when it fails to start, do you hear anything when you turn the key to the start position?
May 21, 2023 at 12:51 PM
GARY FISH
  • 5 POSTS
no factory installed.
May 23, 2023 at 9:42 AM
  • 110,248 POSTS
What I recommend is this. We need to have the can-bus scanned. CAN stands for controller area network. Basically, the different modules are tied together via a few wires so they can communicate with each other. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that explains how to do it:
Let me know if this is something you can do or have done.
May 23, 2023 at 2:13 PM
